Choke Cable has 2 wires
Old Sep 19, 2013
SirJadeye's Avatar
SirJadeye is an unknown quantity at this point
Exclamation Choke Cable has 2 wires
I have a 1977 Civic CVCC Hondamatic, 3BBL carb with manual choke. Previous owner modified the choke cable and now is not long enough to attach to new carb. I was going to replace with a universal cable, but I found that on the original there is a couple electrical wires connected to a little box on the **** end. Those wires run up under the dash. Can anyone tell me what this is, and if it is something that needs to be replaced with an OEM part?
Old Sep 19, 2013
Re: Choke Cable has 2 wires
It's been decades since I have seen one of those! LOL
The first item I see on Hondas website is about a recall on the choke cable mechanism (the heater part of the cable).
In fact, that's about the only thing there, service-wise.
In the description is this:
The manually operated choke is equipped with an override mechanism which will return the choke to the fully OFF position if the driver should forget to do so before the engine reaches normal operating temperature. The override mechanism consists of an electromagnetic coil, a resistor, a choke cable holding plate and a plastic housing.
Pretty sure that's what you are looking at.
I guess if you are used to a hand/manual choke and will remember to push it in at the right time every time you use it, then you don't really need the factory part....if it's even available.
Old Sep 20, 2013
SirJadeye's Avatar
Thumbs up Re: Choke Cable has 2 wires
Thanks a bunch. I found that same info today. I'm going to go with an after market at this point. Cheers
Old Jan 2, 2016
1979cvcc's Avatar
1979cvcc is an unknown quantity at this point
Can you share where you were able to find the choke cable? My 79 cvcc cable broke and I can't find one. If you created it, can you share any details? I really appreciate it!
Dani1993
Jul 24, 2015 09:02 AM
Dave1984
Jul 22, 2015 06:10 PM
sch2cm
Jul 21, 2015 09:58 PM
muttleytm
Jul 11, 2015 06:00 PM
robbie374
Jul 7, 2015 02:56 AM
