86 Civic wagon Head Gasket issue
Old Jul 18, 2013
ionstorm66's Avatar
ionstorm66 is an unknown quantity at this point
I'm replacing the had gasket on my 86 wagon and the previous owner stripped one of the exhaust manifold nuts. Can I just unbolt the cat and pull the head with the header attached?
Old Aug 14, 2013
iim1rmg's Avatar
iim1rmg is an unknown quantity at this point
Re: 86 Civic wagon Head Gasket issue
I think you can. The 84-87 was not nearly as easy to pull the head as later models like the 88-91 1.5.
Also, these 1.3/1.5L engines have a history of going through oil like crazy after doing a head gasket unless you also do rings, valve seats etc. No reasonable explanation of why a head gasket change would make such a difference, but it does.
Good luck.
PS- You have to deal with the stripped stud anyway, so you can also just chisel/cut it off and replace it once you have the head out.
Last edited by iim1rmg; Aug 14, 2013 at 12:55 PM. Reason: add additional suggestion
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
hokiedad4
Apr 30, 2015 07:18 AM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
BREADFAN
Apr 15, 2015 08:58 AM
deus-ex
Apr 13, 2015 12:29 PM
