OBD2 Scanner wont work on 1996 civic?
Old Aug 17, 2013
Saggy's Avatar
Saggy is an unknown quantity at this point
I bought a maxiscan ms309 from amazon. I was going to use it to check my check engine light. But when I go to scan, it always says "LINKING ERROR" I've already tested this scanner on my other cars and it works well? I tried changing the ecu(chipped), reading the codes manually by sticking a pin into the blue plug. (The code i get from the plug is the O2 sensor) But when I changed the sensor the check engine light is still on. What could be the problem?
Old Aug 17, 2013
GolNat's Avatar
Prelude Owner
Re: OBD2 Scanner wont work on 1996 civic?
After you change the sensor you need to restart the ECU. Normally you could do this with your scanner but since its not working I would just disconnect the negative battery cable for a minute or so. This will reset everything and if the light comes back on then the sensor didn't fix the issue or there is another issue.
kevin99ek
Apr 23, 2015 09:32 PM
ashleymmackey
Apr 18, 2015 09:48 PM
darwin-t
Apr 18, 2015 09:29 PM
Killagi
Apr 12, 2015 10:42 AM
