clogged injector cleaning (off car)
Old Nov 5, 2012
atroutslayer's Avatar
atroutslayer is an unknown quantity at this point
my injectors were exposed to some dirty gas. they clogged to the point the car would just start and die.
I soaked them in carb cleaner and tried to blow through them with the solinoid open.
After cleaning I started the car I was able to rev it up but it was idling a little rough blowing some white smoke. Then I started getting worse and I believe the injectors became clogged again.
What is the best way to clean them off the car? Should I blow cleaner through injector with valve open? Should I blow backwards? What is the best cleaner to soak them in?
Thank you. RJR
Old Nov 5, 2012
Re: clogged injector cleaning (off car)
This worked for someone on a S2000 forum....
Be careful, carb cleaner/throttle body cleaner spray is quite flammable.
HTH
EDIT: There are 2 separate videos up there. One didn't seem to link?
mattdoc
Mar 14, 2017 12:10 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
