91 starts then starves for gas and dies
car will idle for a few seconds then die. replaced fuel filter and fuel pump. getting fuel to fuel bar. all ingectors are getting signal to open and close. The "LOW" light goes out after fuel system pumps up. I can get engine to run longer and rev up by dumping a little gas down the air intake tube. I don't know for sure that system is at 38lbs.
Could this be clogged injectors or maybe the fuel pressure regulator?
thank you for your time. RJR
Wild Cranker
427
Jan 28, 2016 06:49 PM
mrcell24
May 19, 2015 10:02 AM
Ashley Farr
May 7, 2015 05:01 PM
black2k1vtec
Dec 6, 2001 09:49 PM
