No power to ecu, fuel pump, and no spark
Old Sep 13, 2012
fergyferg's Avatar
fergyferg is an unknown quantity at this point
I took my dash out of my car to replace it and after i put it back in my car wont start...only cranks. I'm getting no power to my ecu, fuel pump, and have no spark. Ive checked every fuse, every relay, replaced the main relay, ignition, coil, button, and cap. I'm getting 12v to the distributer and have all the main grounds connected. Also, the CEL is on constantly. Ive put to much money into all these parts for nothing. I NEED HELP!!!
Old Jan 23, 2013
chrisfixit's Avatar
chrisfixit is an unknown quantity at this point
Re: No power to ecu, fuel pump, and no spark
my car is a 1986, im having the same problem, idk if its maybe a headgasket blown due to bad oil issues from the previous owner,
my car cranks but wont start,
timming maybe????!?!?!?!
im about to doe the spark test and then the main relay fuse
Old May 19, 2013
ttsupra2503's Avatar
ttsupra2503 is an unknown quantity at this point
When you dont have a signal from the crank sensor saying that the engine is turning over then you wont have ignition, fuel pump or anything else for that matter. However you also mentioned that you not getting power to the ecu, check your wires incase you pulled something off by accident, start by tracing power from the fusebox to the ecu. I know this post is old but I figured someone should answer the question incase someone else runs across this problem.
Jonnie.
Jan 13, 2019 11:21 AM
davidpaustin
Apr 30, 2015 11:20 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
McD
Apr 22, 2015 05:28 PM
