1994 civc lx cruise control not working
Old Aug 24, 2012
fecomosis's Avatar
fecomosis is an unknown quantity at this point
Exclamation 1994 civc lx cruise control not working
I cannot get the cruise control to work.
I am not sure if, with the engine off and key in the run position, should the cruise light be on? a test to see if the lights are functional?
I dont see the light appear, I am not sure if its normal or not.
BUT, things I have checked so far is, all fuses, CC switch, does function, and have the requried 12v lines. I am not sure that, if the bulb is out, that the module is actually working, but the other half is not.. any ideas?
While driving, cruise switch is on, no green light, I hit the set button on the steering wheel, and nothing.
94 civic lx w/abs
Old Aug 30, 2012
94civicdahall's Avatar
94civicdahall is an unknown quantity at this point
Re: 1994 civc lx cruise control not working
have you had the steering wheel off for anything? I know that sometimes the switch on the side of the steering wheel can come disconnected from the harness...its really easy to check...pop the cover off the cruise control buttons...its on the side...take the 2 screws out and check the connection...then put it back together and try it out...I know I dont see my light come on until night time...its dim...but my cruise control light in the dash comes on and can see it with no issues...unless your bulb blew
Old Aug 30, 2012
fecomosis's Avatar
Ok, I will check thanks!
Also, when you hit the cruise main power button on the dash, does the green cruise light show up or not until someone hits the set button?
Old Aug 31, 2012
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
i had similar problems and i just changed the cluster and it fixed it.
Old Sep 9, 2012
Mike91W's Avatar
Mike91W is an unknown quantity at this point
I have a sort of similar problem with my 94 si coupe, except my horn doesnt work, srs light on, and my cruise button turns green but the one on the dash doesnt. I also did find a loose plug under my dash. can't figure out where it goes.. should i just bring it to a shop or try some alternatives?
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
cukaracha
May 16, 2015 02:11 PM
usajags84
May 10, 2015 08:11 AM
ORskier
May 3, 2015 12:54 PM
Civic316
Electronics
Dec 10, 2001 12:03 PM
