Grinding noise when turning
Old Aug 17, 2012
b_rad_ot's Avatar
b_rad_ot is an unknown quantity at this point
ok i keep hearing this sorta grinding noise coming from the front driver's side wheel only when i start to turn right. the cv axel looks alright so i'm thinking it may be the wheel bearing does that sound right? If it is anybody have any suggestions on where to buy a wheel bearing ?
Its a 1994 civic ex the power steering has been taken off idk if that might have something to do with it
Old Aug 18, 2012
EG2323's Avatar
EG HATCH
EG2323 is an unknown quantity at this point
Re: Grinding noise when turning
Up sounds like the wheel bearings to me
Old Aug 19, 2012
Fragmare's Avatar
Fragmare is an unknown quantity at this point
Err, yea... if you're *positive* the axles are good, then probably wheel bearings. Jack it up and hold the wheel at 12 o'clock and 6 o'clock and shake it. If there's play, or if you spin the wheel by hand and there's noise, it's your wheel bearing. Check your ball joints and bushings too while you're down there inspecting stuff.
Keep in mind, though, that just because the dust boot on the axle(s) is/are still intact, it doesn't mean they're not acting up. If you've pulled them for any reason lately (transmission work, etc.), I'd be suspicious. Those axles don't take well being pulled the wrong way.
rtachs
Jul 16, 2015 05:32 PM
civicns
May 8, 2015 09:49 PM
edgenet
May 2, 2015 08:00 PM
EC3
Apr 22, 2015 07:55 PM
SSMatey
Apr 13, 2015 06:09 PM
