Help!! I think I messed up!!
Old Mar 30, 2012
n01d3x's Avatar
n01d3x is an unknown quantity at this point
Just bought a 93 civic dx (15b7) not too long ago. Has a short ram intake, and what looks to be some cheap exhaust tip. Other than that bone stock. I am an extreme novice as soon as I open the hood. I attempted to do a tune up today. It failed smog, was a little high in the NOx column. I changed the fuel filter, plugs, wires, cap, rotor, oil filter and oil. Everything went ok and I was attempting to make sure my ignition timing was ok. The car warmed up and all was fine. I noticed I had the wire from ch3 and ch4 crossed, so i turned off the car and switched them. As soon as I did this the car now idles up and down extremely bad. The timing mark also jumps all over the place. I tried putting the old cap, rotor, wires and plugs. That changed nothing. What did I do? Also, I cleaned the idle air control valve. The seal is not in great shape, not absolutely trashed, but could use replacing. No one around me has just the gasket.
Old Apr 1, 2012
Riick's Avatar
Riick is an unknown quantity at this point
Re: Help!! I think I messed up!!
Maybe I'll have a big "DUH" moment once I find out, but could you please tell me what ch stands for so I can figure out what wires you're talking about?
Order it online - there's a ton of honda parts websites:
www.hondapartsnow.com
www.hondapartscheap.com
www.hondapartsdirect.com
...and probably about a gazillion others.
Old Apr 1, 2012
BlueEM2's Avatar
Whachya lookin at?
So.. The car ran fine, then you switched the wires? Switch them back. Ch wires are obviously ignition wires. I think.
Old Apr 1, 2012
lazlong's Avatar
Where are you looking when you say timing marks, distributor or timing belt? Sometimes you can't just replace the cap and rotor, sometimes you need the whole dist. Just for sh*ts and giggles try to see if it has any codes: http://check-engine-light-codes.blog...retrieval.html
Old Apr 5, 2012
sellis1552's Avatar
sellis1552 is an unknown quantity at this point
By just switching those two wires you could have messed up your firing order. You need to do one plug at a time in order when replacing plugs or the wires. Try removing and replacing each plug one at a time, as in, take out the first one, replace it, and secure that one. Then move onto the second.. etc.
Tyler93
Mar 20, 2016 09:03 PM
Munzy
21
Oct 7, 2015 07:48 AM
Dsmak
Sep 10, 2015 08:30 PM
Dave Brabant
Sep 10, 2015 06:48 PM
Bricoleur
Sep 9, 2015 12:30 PM
