Trany question
Old Jan 10, 2012
Hatchback_0702's Avatar
Hatchback_0702 is an unknown quantity at this point
Trany question
I have a b16a hydro trans, am I only limited to a b16a motor or can I use any b series motor?
Old Jan 11, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: Trany question
In short yes B will fit B.. I have seen a B16 S1 tranny on a B18A...
Old Jan 11, 2012
Rockys_93civic's Avatar
Rockys_93civic is an unknown quantity at this point
Question Re: Trany question
Gunner does the same apply to all D series motors and auto/manual tranny too??
Old Jan 11, 2012
Gunner's Avatar
Re: Trany question
To my knowledge yes...however there is more involved if you switch from auto to manual..
Old Jan 11, 2012
I guess I should have stated my question better. Ok here I go .. I have a auto tranny with D15B7 and I wanna do a swap to D16Z6 but it's a manual tranny but I wanna keep my auto and so with all the d series motors will the motors bolt up to and D series tranny regardless if it's automatic or 5speed??
Old Jan 12, 2012
Gunner's Avatar
Re: Trany question
I will have to check on it but i think there is a lot involved going from manual to auto..Most people do swap auto to manual but the other way around requires more parts..I dont think you can just take a manual motor and plug and play an auto tranny..you have to get all the pieces in between..I think and don't quote me without looking into it more you will have to change the harness, cv axles (i think), and shift mechanism, tranny mounts and probably the ecu. From what i read it will bolt up however you have to make sure you have all the right internals..Someone correct me if i am wrong...
robjcivic
Mar 12, 2017 12:10 PM
0396
May 4, 2016 07:14 AM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
