'95 Civic won't start when warm...
Old Jan 8, 2012
timmerz's Avatar
timmerz is an unknown quantity at this point
My Grandson's Civic won't immediately re-start after shutting it down when it's warmed-up...has to cool down for 20 min. to 1/2 hour before it will start again....cranks over very well when warm, just doesn't fire....is there a coolant temp sensor that would cause this like on my Saturn, or is the culprit more electricaly-oriented? Anybody had to diagnose this one before? Thanks in advance if anybody's able to help..
Old Jan 9, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: '95 Civic won't start when warm...
check main relay...could be a loss in the fuel pressure..Could be a leak in the injectors or fuel pressure reg or something like that..would have your fuel pressure checked..
Old Jan 10, 2012
timmerz's Avatar
Thanks for the response, Gunner....when you say Main Relay, are you referring to the Main Relay for the fuel pump, or another main relay I need to look for under the hood?
edit: As far as leaks go, everything's tight under the hood, no leaks showing at all...
Old Jan 10, 2012
Gunner's Avatar
The main relay for the fuel pump.. things i have seen cause this problem are
fuel pressure regulator
bad injectors
Leak in the fuel system.
bad ignition control module(not as common)
Bad grounds on main battery ground(not as common)
Old Jan 11, 2012
timmerz's Avatar
Thanks for the info! I'll start with the fuel pump main relay, then see if I can find someplace to test the fuel pressure for us...
Jonnie.
Jan 13, 2019 11:21 AM
vtec92
May 4, 2017 03:20 AM
Braun
Apr 23, 2015 09:03 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
