2000 Civic Si Bogging at high RPMs in rain?
Old Dec 5, 2011
rileyb22's Avatar
rileyb22 can only hope to improve
Title basically says it all. Im not sure why its doing this but it seems that everytime its raining and i get up to around 4500 rpms, i get a nasty bogging sound and it feels like its lost power. Can anyone give me some tips as to what this might be? I have recently replaced the 02 Bank 1 sensor.
Old Dec 5, 2011
HondaDr's Avatar
HondaDr is an unknown quantity at this point
Re: 2000 Civic Si Bogging at high RPMs in rain?
I had the same problem in mine and then it started through a cel code. Which turned out to be a sensor in the distributor. It was not advancing correctly and causing the bogging and spluttering at high rpm's. I got a used ditributor and it went away.
Old Dec 5, 2011
rileyb22's Avatar
How much did you pay for it used? And why would this only be happening when its raining?
Also, my check engine light is on, but all that comes up on the computer is the iacv
Old Dec 5, 2011
HondaDr's Avatar
Never found out why it only did it when it was raining. Once I swapped it out it went away.
I thought maybe there was a seal issue and some how water got in there but its a bit of a jump to get up there and I wasn't submerging the car lol.
Cost of a used one was $75 off ebay.
This may not be your problem but it does sound exactly like what mine was doing.
You could also check your engine grounds. Make sure they are all good. This can cause some issues with high rpm's but it would affect in the dry as well.
Old Dec 5, 2011
rileyb22's Avatar
Okay, should i replace the distributor rotor, or the whole distributor?
Since it is not showing up as anything on the CEL, then what else could it be?
Old Dec 5, 2011
moisture in teh distributor, most likely
Old Dec 5, 2011
maxtierney's Avatar
EM2ti
X2. Some people go as far as sealing their dizzy caps with a little silicone to prevent moisture/condensation and using elctrical lube on the wires.
Old Dec 5, 2011
rileyb22's Avatar
Thanks. So basically i should just replace it and seal it just to be safe.
Old Dec 5, 2011
cheap ones first - try to seal it - if does not work, go for another one.
Old Dec 6, 2011
rileyb22's Avatar
Hey everyone, well today it is still raining and it did not bog or lag at all. It felt normal and it pulled strong.
I dont want to go replacing things if i dont know if there bad or not. Any new ideas?? They are much appreciated
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
