Performance?-Valve Clearance Adjustment
Old Nov 28, 2011
rileyb22's Avatar
rileyb22 can only hope to improve
Unhappy Performance?-Valve Clearance Adjustment
My 2000 Honda Civic Si needs its valves adjusted. It has AEM cams, with a belt that's a bit loose on them. I have a guy thats taking care of it all this week. Once all this is fixed will my car run better? I feel like its not running how it should. V-tech isn't pulling as hard, and It feels kind of hesitant as I'm slowly climbing RPMs.
Oh and also the check engine light IS on, but a test has been ran and all that its showing is my IACV going out. Nothing else..
Old Nov 28, 2011
Re: Performance?-Valve Clearance Adjustment
only if the valves were out of spec to start with
Old Nov 28, 2011
AEM cams? ya mean the cam gears? AEM does not make cams
Old Nov 30, 2011
rileyb22's Avatar
Thats what i meant. I figured out the problem. It was a combination of the valves needing adjusted and the bank 1 02 sensor being replaced. All was fixed and it runs great now
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
MamaBear2015
Sep 27, 2015 06:31 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
