blinker problem
Old Oct 24, 2011
miserysmine's Avatar
miserysmine is an unknown quantity at this point
Exclamation blinker problem
i bought an 88 civic dx from sum kids for 500 bux had to replace the clutch got that dun then the battery, ignitioon switch, relay, full throttle body, brakes, drive shafts, etc etc. got it all done now when i have the car in neutrul the blinkers work fine as soon as i put the car in reverse and only reverse it blows the fuse no matter wat size fuse is in there any thoughts on wats causing this problem.
Old Oct 29, 2011
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
Re: blinker problem
did you replace all your grounding wires correctly. There is one from valve cover to chassis and some civics have one from Thermostat housing to chassis, also.
Old Oct 29, 2011
Re: blinker problem
i ended up sendin it to the shop when i replaced the clutch and they replaced all the parts and also my gas gauge and temp gauge wont work either
MyCivic
Electrical
Oct 28, 2021 11:06 PM
jtdunn4life
Oct 27, 2015 03:33 AM
form3hide
Jan 19, 2002 06:36 PM
SneakerPimp
Jan 8, 2002 05:27 PM
Hondasport01
Dec 17, 2001 01:53 PM
