Oil in Spark Plug Tube
Old Jul 28, 2011
rmdt4's Avatar
rmdt4 is an unknown quantity at this point
I have a 1995 Civic. I just changed the plugs/wires and found oil on 3 of the 4 plug tubes and plugs themselves.
What could be causing this?
Thanks,
RMDT4
Old Jul 28, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
Re: Oil in Spark Plug Tube
where the spark plug tubes meet the valve cover there is a gasket around every spark plug tube you replace that and you wont have oil on your spark plugs
Old Jul 28, 2011
MindBomber's Avatar
Live for the Twisties
^exactly.
I think you can buy them individually for a couple dollars each or the entire valve cover gasket set for around $25.
Old Jul 28, 2011
MelJ's Avatar
Trance Addict
I personally think it's better and wiser to just get the entire kit, as it comes with the grommets for the cover bolts as well. And those things can leak a little as well and crack over time. But yeah. Last 2 replies are spot on. I
JohnnyBxo
16
May 9, 2015 05:53 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
MikeyBoy
Jan 26, 2002 06:45 AM
joefufu419
Bolt-on Engine Performance
Jan 7, 2002 09:18 PM
Micks2K1
Dec 10, 2001 07:11 PM
