starter issues
Old Jul 27, 2011
bankswood's Avatar
bankswood is an unknown quantity at this point
starter issues
I have a 91 civic dx manual tranny. With no previous warnings my starter stopped working. when I turn the key its like the battery is completely dead. tried to jump it but same problem. pushed it off and it runs fine. took it to a parts store and they tested battery and alternator and both are good. I pulled the starter and had it checked and it failed so I bought a new one and installed it. Same result. when I turn the key absolutely nothing happens.
Any help would be appreciated
Old Jul 30, 2011
lazlong's Avatar
Re: starter issues
Start by checking fuses 31 and 32. If the fuses are good then dis-connect the black/white wire from the end of the starter solenoid. Use a jumper wire and go from battery positive to the terminal you just dis-connected the black/white wire from. If the jumper wire makes the starter turn then there is an open in the black/white wire between the ignition switch and starter.
Abb0nz
Jun 23, 2015 06:10 PM
Mnealo
Jun 18, 2015 10:11 PM
Mich2019
Jun 7, 2015 11:23 PM
Allecr3
May 22, 2015 01:24 PM
gabrown2
Apr 11, 2015 08:22 PM
