d16z6 to d15b7 downgrade
Old Mar 10, 2011
juanchi's Avatar
juanchi is an unknown quantity at this point
I had to put a d15b7 into an EX chassis. The EX was automatic tranny and the d15 is standard. Everything mechanical is ok but the wont start. I think im missing something electrical. Both are '94 Civic.
Old Apr 11, 2011
foslhntr's Avatar
civicfixer
foslhntr is an unknown quantity at this point
Re: d16z6 to d15b7 downgrade
I had a similar problem with a 96 Honda Accord, for what it is worth, the ecu may be missing a sensor input from the automatic transmission. If you plug in a code reader (OBDII for the 96 Accord), the reader bypasses the sensor input and the car will start and run, but you will have to leave the reader plugged in to run the car. Maybe this will work with your 94 Civic. Good luck
Old Apr 15, 2011
84civicawd's Avatar
84civicawd is an unknown quantity at this point
There's a solenoid that you have to reconnect that alot of people miss it's on the chassis
soufigured
15
Aug 18, 2015 08:22 PM
Klame9420
Aug 13, 2015 06:00 PM
CivicsClass101
Jul 9, 2015 11:14 AM
