Parts for head gasket replacement
Old Jan 14, 2011
redright9's Avatar
redright9 is an unknown quantity at this point
So, going to replace the head gasket on my civic, 1995.. What is the best kit to use (cost and quality)... and also a head bolt kit.. I found one from arp but it is a head stud kit. I just want to replace with factory style bolts.
Old Mar 7, 2011
Smurfcar's Avatar
Smurfcar is an unknown quantity at this point
Re: Parts for head gasket replacement
Use a felpro set and you dont need new bolts just clean the threads the dont streatch like on most american cars.
Old Mar 9, 2011
J-Master Flex's Avatar
J-Master Flex is an unknown quantity at this point
If you're looking for cheap, but quality parts, check out majestichonda.com. I've always had a good experience with them. Also, I'd definitely recommend the tri-metallic headgasket.
And definitely keep the head bolts you already have, unless you absolutely need new ones. And be sure to remove and install them in the proper order and to the recommended torque specs.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
hokiedad4
May 3, 2015 10:06 PM
hokiedad4
Apr 30, 2015 07:18 AM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
green01civic
Apr 29, 2015 01:36 PM
