94 ex coupe tranny problems
Old Mar 2, 2011
Too_Fresh's Avatar
Too_Fresh is an unknown quantity at this point
When in bought this car i was told the throw out bearing was bad in the tranny and some other bearing ( not sure what said "some other bearing" is ). There is almost a grinding noise sometimes in low and high RPMS. It will go away as quick as it came when accelerating then come back as quick as it went lol. Some times it doesn't make it at all. And yes it does make a weird noise when you push in the clutch. I went to some mechanic shop and they told me " My transmission will explode sooner or later " then they tried to sell me a used tranny for 800 dollars plus 300 for labor. So i cant really trust that seeing as how it sounds like a load of **** obviously. So my question is. Could my tranny be going out? Or do i just need a new clutch, throw out bearing and possibly this mystery bearing? The sound is alot more noticeable in 1st - 3rd. But makes it at certain RPMs in 4th and 5th. usually around 3 grand. Any insight or help is much appreciated. thanks
EDIT. Forgot to say that when in neutral you can here the noise as well. But when you push the clutch in.. all is well, It sounds perfect no noise
Old Mar 2, 2011
MelJ's Avatar
Trance Addict
Re: 94 ex coupe tranny problems
sounds like it could be the release(throwout bearing). that other mystery bearing you're thinking of is the pilot bearing.
Old Mar 2, 2011
Too_Fresh's Avatar
Pilot bearing, ok. So i should probably track down a reliable mechanic and get a new clutch , throw out bearing and pilot bearing? Probably will just to be on the safe side, I just get paranoid sometimes that it is really the transmission. But I think it is highly unlikely.
Old Mar 9, 2011
J-Master Flex's Avatar
J-Master Flex is an unknown quantity at this point
I had the same exact problem on my '97 Civic, and I'm pretty sure it was the input shaft bearing. I don't know if there's a great difference in the transmissions on 5th gens and 6th gens, but that would be my guess.
Poopies
Apr 20, 2017 11:36 PM
MajTom
Jun 2, 2015 11:48 AM
bo_red
May 26, 2015 07:25 PM
dosmastr
May 5, 2015 12:19 PM
Civicman92296
Apr 23, 2015 09:22 PM
