expert advice needed!!
Old Dec 21, 2010
94civicman's Avatar
94civicman is an unknown quantity at this point
I have just bought a 94 civic 1.3 dx and i was just wondering if anybody has any knowlegde as to why i cant get over 65mph? do these models have restrictors which limits the speed and if so...how can i take it off? cheers.
Old Dec 21, 2010
Re: expert advice needed!!
Any maintenance records?
Old Dec 21, 2010
Mad Dog Tannen's Avatar
That sounds weird. What country are you in? Do they have governors set that low on cars there?
Old Jan 3, 2011
StaticFire450's Avatar
Bringer Des Blutes
StaticFire450 is an unknown quantity at this point
Check your timing. Just yesterday I was working on a Mazda. It was firing AFTER top dead center... I could not rev up passed 3 on the RPM gauge. Notched back the timing to right before TDC... Vrooooooomm!!! Up to 8 on the RPM gauge.
But you said MPH not RPM.... Have you tried revving the engine up, whilst in park/neutral??
Old Jan 20, 2011
"goose"Jay's Avatar
"goose"Jay is an unknown quantity at this point
whoa whoa whoa 1.3? i was pretty sure they stopped making d13's in like the early 80's? I had the same problem with my coupe it was 2 major things that i can remember doing it, the timing was off and the map sensor was fouled with no MIL. Try doing both of those, then popping the ecu and back up fuse out and resetting the ecu and see what she does then. Good luck
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
cukaracha
May 16, 2015 07:36 PM
crowtoo
May 11, 2015 06:50 PM
Jigee
May 9, 2015 11:18 AM
Myredjonda
Apr 14, 2015 07:00 PM
