Won't start in the rain! Help!
Old Dec 20, 2010
Croxton's Avatar
Croxton is an unknown quantity at this point
Hey guys,
I just came out to my 95 Civic and found that it won't start. It's turning over but wont start so I'm suspecting some electrical problems. Figuring that this only happens when it rains (this is the second time this has happened) there must be some leak somehere right? Im thinking the distributor cap? Has anyone else had this problem on a civic or does anyone have any advice? Thanks in advance!
-Croxton
Old Dec 20, 2010
Mad Dog Tannen's Avatar
Re: Won't start in the rain! Help!
First fiure out weather it is a fuel or spark problem. Remember that your fuel pump and injectors use electricity too. Try and get the ECU checked for soft codes, that may point you in the right direction. Unfortunately it is kinda hard to trouble shoot when it's not happenening. Check for exposed wires (worn insulation) that could be exposed to water. Look for exposed frame metal or other conductive surfaces next to the exposed wires.
It could be that the water is causing a short somewhere.
usajags84
15
Aug 19, 2015 03:12 AM
ashlava71
May 16, 2015 12:54 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
black2k1vtec
Dec 6, 2001 09:49 PM
