Stall after warm
Old Jan 14, 2007
rudybellavia's Avatar
rudybellavia is an unknown quantity at this point
Stall after warm
Hello All,
I just put in a new cylinder head and got the car started w/o any problems. When it it cold it idles fine but once I drive it around or let it idle until it warms up it will die. It seems to happen when it reaches a certain temperture but can't figure it out. I have a new thermostat and I have even disconnected the sensor to see if that was the cause but no luck. I did not touch the idle, the throttle etc so I am at a loss as to what it casuing this to happen. I have no lights come on and it drives great. Any help or direction is appreciated.
1993 civic dx 1.5l 2 dr coupe
Last edited by rudybellavia; Jan 14, 2007 at 04:28 PM. Reason: forgot specs of the car
Old Jan 15, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
You may not be getting enough fuel. The newer cars ECU idles higher when starting until reaching operating temperature then it idles normal. Your motor may be needing that extra fuel and when it warms up and idles down it's not getting enough fuel to run. Just a thought.
Old Jan 15, 2007
So when you say not getting enough fuel what do you suggest?
The car did sit for several months before I got it taken apart and back together..
Old Jan 15, 2007
sql_civic's Avatar
Hi Rudy,
I'm not real familiar with your generation civic, however I am real familiar with the 96-00.
Your idle is controlled by your IACV. On some models of the 96-00 civics it's easy to mix up the 3 prong connectors on the IACV and TPS. Make sure you don't have these switched!
Other things:
Make sure your IACV is nice and clean (not clogged).
Set your idle and timing.
Good Luck.
Old Jan 15, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
my thoughts are its ignition related. I often get a studder after my spark plugs have gone a few thousand miles.... Emanage has something to do with it in my case, but it only happens when the car is "warm" as in... run it park it for a few hrs and start it back up. Damn thing wont stay on, but it only happens when the plugs get old. I'd say start with the plugs... it might be something as dumb as that. If not, look into the wire and the coil, etc... and check the timing.
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
winanthony94
Sep 25, 2015 09:05 AM
2.0.0.2
Sep 14, 2015 06:38 PM
thaler4cuse
Sep 7, 2015 08:25 PM
tommycanada
Sep 5, 2015 04:59 PM
