Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
98 AWD civic coupe (automatic)
Old Jul 4, 2022
jeloi1's Avatar
jeloi1 is an unknown quantity at this point
im building an awd automatic civic. I swapped everything out of an automatic 99 cr-v awd. the car starts and im in the final stages of the build but im having some issues. 1) my civic is OBD2a and the cr-v was OBD2b; i used the cr-v OBD2b ecu and engine harness and everything has plugged up except for one of the major plugs on the driverside firewall. do i need a jumper harness? 2) when i try to put the car in gear it does not go into the proper gear; i was told the gear shifter cable out of a 94-2001 acura integra is what i need. do i need a gear shifter cable for the b-series automatic transmission? 3) i converted the civic to 5 lug using the cr-v front spindles. however, the cr-v axel has a 36 spleen which fits in the hub but the length is too long for the civic so i used the axel from another car. but now in the front passenger side, the wheel is not spinning properly. i think its the axel but im not sure. wheat axel should i use?
Melherring
Feb 19, 2015 01:09 PM
skramer
Jul 30, 2014 03:09 PM
ikutuof
May 30, 2014 07:29 AM
Cheapshot
Jan 17, 2014 08:44 PM
DavidRey
Mar 18, 2012 02:14 PM
