Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
d16y7 swap
Old Oct 30, 2011
swagger9000's Avatar
swagger9000 is an unknown quantity at this point
d16y7 swap
I read the articles and I understand what motor/trans I have, but I didnt understand the list of motors that could be swapped into my 97 dx.
Are these the motors that can a swapped with the d16y7, or are these meant for something else?
https://www.civicforums.com/forums/2...er-models.html
6th Generation
1. B18C1: Completely bolt-in swap, VTEC needs to be wired.
2. B16A2: Completely bolt in swap, VTEC needs to be wired.
3. B16A3: Completely bolt-in swap, VTEC needs to be wired, OBD Conversion.
4. B18C5: Completely bolt-in swap, VTEC needs to be wired.
5. B18B1: Completely bolt-in swap.
6. B16B: Completely bolt-in swap, VTEC needs to be wired.
7. H22A: Mount kit required, Hasport shift linkage, VTEC needs to be wired.
8. D16Z6: Completely bolt-in, OBD conversion, VTEC needs to be wired.
9. D16Y8: Completely bolt-in, VTEC needs to be wired.
Thanks for the help.
Old Oct 30, 2011
lazlong's Avatar
Re: d16y7 swap
Don't understand the question. Yes, you can swap those engines for yours. They came out of different vehicles. Like the Z6 came out of JDM (Japanese Domestic Market) SI-R's, etc. For a list of which engine comes from which vehicle search wikipedia. Use the search term "honda d engines", etc.
Old Oct 31, 2011
Re: d16y7 swap
excellent, thank you.
Old Mar 29, 2012
njm[b18b1]1993's Avatar
njm[b18b1]1993 is an unknown quantity at this point
Re: d16y7 swap
yeah your all good , i got a b18b1 in my 97 dx civic. just be careful and switch the right ecu , your motor will lean and you will lose compression if not
Scout1
Oct 5, 2015 01:33 PM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
PunX
Sep 23, 2015 10:45 PM
Bruce2
Sep 21, 2015 08:01 PM
