Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
1999 civic si jdm b18b questions
Old Mar 17, 2011
stoker34's Avatar
stoker34 is an unknown quantity at this point
I just bought a 99 civic si and it has the following already done to it:
JDM B18b block with GSR head LS VTEC
bored out, unsure how much
Spoon head gasket
Apr studs
Aftermarket rods and pistons
Type r header
Apexi WS2
AEM cold air intake
Head was port matched on exhaust port .010
Titanium valves and retainers
Accelerates distributor cap NGK plugs and wires
Wrinkle coated valve cover
GSR trans
Exedy clutch , pressure plate, flywheel
Drilled slotted rotors.
My question is about how much hp "could" or "should" it be producing and does everything done to it seem logical?
I am a new member to the forum and hope to learn a lot. Thanks
Old Mar 17, 2011
MindBomber's Avatar
Live for the Twisties
Re: 1999 civic si jdm b18b questions
There's not nearly enough info there to give a solid guess, but the seller should have had it dyno tuned and included the sheets with the sale?
Old Mar 17, 2011
stoker34's Avatar
As far as i kno there are no dyno sheets with the car. The guy i bought it from was the second owner and the guy before him had the swap done
Old Mar 17, 2011
MindBomber's Avatar
If it wasn't properly tuned or you don't know if it was your first investment should be an hour on a dyno with a tuner. Just to make sure the everything is set right, bad tunes kill engines.
Old Mar 17, 2011
stoker34's Avatar
alright thanks man
Old Mar 28, 2011
99sicivic's Avatar
Josh
99sicivic can only hope to improve
Does it idle rough ? if so it will need a tune u badly i also have 99 si civic with b18 in it
usajags84
15
Aug 19, 2015 03:12 AM
usajags84
May 10, 2015 08:11 AM
aultman1990
Apr 19, 2015 07:14 AM
NROD315
Apr 16, 2015 08:40 AM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
