Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
Losing power?
Old Oct 12, 2009
BlueSi321's Avatar
BlueSi321 is an unknown quantity at this point
Losing power?
I have a jackson charger on my '00 Si and I think I'm losing power. I was wondering if it had anything to do with my muffler having a pretty good size hole in it, or something to do with my o2 sensor? Or if it would be the tuning on the charger itself. Because I noticed a significant change in the power in my car the other night when running high rpm's. I lost to a stock '02 si hatch with a k20 motor... and I honestly don't think I should have lost if my charger was running correctly..
What do you all think? I'm fairly new with this car and everything on it.. so any help is appreciated.
Clay
Old Oct 12, 2009
BlueSi321's Avatar
Re: Losing power?
Oh and could changing the type of oil be the problem? Because just before noticing this, I had my oil changed from regular to synthetic...
Old Oct 12, 2009
Re: Losing power?
its possible the oil had something to do with it if it happened suddenly after changing it. usually small exhaust hole wouldnt do anything, as long as its after the o2 sensors. and double check your tune, make sure the fuel maps didnt change.
Old Oct 12, 2009
ronaldo9's Avatar
Re: Losing power?
If everything is intact minus your hole, I'd look at the tune. Do you have a wideband? What fuel management system are you running? W/o knowing how much boost you are running or what you're tuned for its quite possible you could lose to a stock k20(a2), since you could potentially be putting down the same power to the ground.
Old Oct 12, 2009
BlueSi321's Avatar
Re: Losing power?
I'm really not sure if it's wideband..
Usually when I get on it running high rpm's I push close 9-10 psi on the boost gauge.. also my air/fuel ratio gauge is not working correctly.. So maybe the charger is getting plenty of air, but not enough fuel? I'm going to contradict myself and go ahead and say its probably not my oil haha.
I'm going to put it on the dyno next week after I get my new muffler and hook it up to the computer and get them to figure out whats going on and tune it and fix my air/fuel ratio...
Old Oct 21, 2009
HondaLuver's Avatar
Its a celebration bitches!
Re: Losing power?
tune it
Old Mar 1, 2010
boha's Avatar
boha is an unknown quantity at this point
Re: Losing power?
Oh goodness lad. You may have lost power due to the racing competition you participated in. The civic is not a race machine and should not be abused. It is a gentle machine for light duties only, and racing is not its intended purpose. Do not ruin your civic, if you must race, then any other car at a dealership is more appropriate for performance such as competing in racing activity. Please give this fine automobile a life free from abuse, its a gentle sweet little machine that you should be nice to and it will be nice to you.
Old Jul 4, 2010
Devin Eaton's Avatar
Devin Eaton is an unknown quantity at this point
Re: Losing power?
and your a fagget for posting what you just posted
Old Aug 27, 2010
NORTHERN95CIVIC's Avatar
NORTHERN95CIVIC is an unknown quantity at this point
Re: Losing power?
it has to do with two things, 1. oxygen sensor 2. bad timing is there an engine light on? if it is its most likely is o2 sensor. have u had your timing belt changed before u lost power?
Old Aug 28, 2010
20_CiViC_02's Avatar
20_CiViC_02 is an unknown quantity at this point
Re: Losing power?
700whp beast. Not a gentle machine.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
0396
May 4, 2016 07:14 AM
Dave1984
Jul 22, 2015 06:10 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
ZILLA
Jul 13, 2015 04:52 AM
