Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
Header Wrap
Old Feb 4, 2008
kentaa78's Avatar
kentaa78 is an unknown quantity at this point
Header Wrap
I was wondering if anyone has used header wrap and if so what results did they get? I have a b16 turbo CRX and my oil temp gets up to 270 if I drive long distance at a high rate of speed. Thinking that the turbo manifold putting out all of that heat doesn't help.
Old Feb 4, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
Re: Header Wrap
that's pretty hot bro, mine barely reaches 190 after a bit of "spirited" driving...i would look elsewhere to reduce your temps. coolant, water pump, thermostat. also are you running an oil- or water-cooled turbo, because that will def affect your temps. if oil-cooled, i would look into an external oil cooler and a good place to mount it. also, at temps like that, you may be endanger of warping the head, be careful
Old Feb 4, 2008
kentaa78's Avatar
Re: Header Wrap
My coolant temp is fine. It stays around 190. I can run the hell out of my car as long as it is stop and go. My turbo is oil cooled only. I cannot find a place to stuff an oil cooler on my car. Intercooler takes up the whole front bumper.
Old Feb 4, 2008
kentaa78's Avatar
Re: Header Wrap
I am thinking about getting a bigger oil pan to see if that helps.
Old Feb 4, 2008
speedfoos's Avatar
Re: Header Wrap
Tony, your oil temps only reach 190? You sure? That's what my coolant temps are at, but oil stays between 210-220 on street driving and about 230 on the highway.
Stick the cooler on the front of the oil pan on the the bottom of the tranny and make a duct and point it at. Or stick it in the corner of your bumper with a duct, or in between the raddy and FMIC. All kinds of places to put it if you're creative.
Old Feb 4, 2008
kentaa78's Avatar
Re: Header Wrap
Sorry bad at explaining stuff. My coolant is around 190 heavy driving. It is my poil temp that soars to 270. This is only driving at 60-70 for about 30-45 minutes, cause the turbo is spooling constantly. I have to crawl under and look at where you are saying. I actually already bought an oil cooler but gave up when I could not figure out a location. Maybe should of looked before I bought it. It is 19 row so kinda big. Between the intercooler traction bar and piping it is going to be a bitch. I know now that there is no way it is going between intercooler and radiator or behind the bumper. Thanks for the suggestion.
Anthony
Old Feb 4, 2008
Re: Header Wrap
header wrap = bad
jet-hot.com = good
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
jdh022764
18
Nov 3, 2015 06:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
anubis62
Sep 27, 2015 12:56 AM
