Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
B16 Turbo?
Old Aug 4, 2007
Prophecy's Avatar
Prophecy is an unknown quantity at this point
B16 Turbo?
Alright, so I have a b16a2, the engine was rebuilt about 23k miles ago.
Nothing performance, the engine was just replaced with stock parts.
What I'm asking is, would it be safe to turbo it now?
And if so, which turbo would be my best bet?
Thanks.
Old Aug 22, 2007
FBHsukka's Avatar
FBHsukka is an unknown quantity at this point
Re: B16 Turbo?
Old Aug 22, 2007
ronaldo9's Avatar
Re: B16 Turbo?
What was rebuilt? The block, head, or both? I'd assume you can turbo the car at any mileage granted the motor is healthy meaning the compression in your cylinders are to spec.
Old Aug 22, 2007
FBHsukka's Avatar
Re: B16 Turbo?
Would the turbo still run okay on a b16 because of the high compression?
Old Aug 22, 2007
ronaldo9's Avatar
Re: B16 Turbo?
Yes you can turbo any car you just need to run high octane and keep the boost to under 10psi until you get low compression pistons. If you have a good engine management system you can always retard the ignition timing so you don't detonate.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
idigturbo
Aug 22, 2015 02:43 AM
justcruzin125
Aug 11, 2015 09:09 PM
Ccoop87
Jul 9, 2015 03:26 PM
