99 civic lowering help!
Old May 16, 2008
Y0ungM0ney's Avatar
Y0ungM0ney is an unknown quantity at this point
So i bought a set of coilovers and coil seats (no struts or shocks) to lower my 99 civic EX.
I successfully got the coilovers on the car with the aluminum coil seats. I noticed as i was doing this there were stickers on the coils separating the two front coils from the back pair of coils. The front coils were noticably shorter in height than the back coils.
I started with the two front coils and slammed it in front. The "O rings" on the coil seat are about half way up on the seat so its not totally slammed.
However, the back "O rings" on the coil seat are slammed all the way to the bottom and the back has not lowered very far at all and cant go any lower i assume since the O rings are all the way at the bottom of the coil seat.
So my problem is that the back coils didnt lower my car much at all but the front coils worked. I cant decide whether the company got the stickers separating the front coils from the back coils switched.
I figured the front coils would be taller to compensate for the weight of the engine. After all, its not a truck which has higher coils in the back to compensate for weight in the back or hauling things. I know i could cut a coil or two off the back coils but i really would like to avoid that.
Anyone know what my problem is? I need to get the back of my civic lowered! Please help
Old May 16, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: 99 civic lowering help!
Usually rear springs are shorter. Are you sure you didn't mix them up? Who makes them?
Old May 16, 2008
greeen01civic4d's Avatar
im guessin egay
Old May 17, 2008
Y0ungM0ney's Avatar
yea got em off ebay. they were cheap but worked well. rear springs are usually shorter? thats what i figured and im hoping the front will still drop with those big springs on front
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
EvilTwin
Nov 8, 2001 12:17 PM
2Hondaz
Nov 8, 2001 11:00 AM
Zillaaa
Nov 2, 2001 05:11 PM
