Need help for a DIY project..
Found this forum doing a google search for DIY..
I own a 2000 Civic EX (2-door, if that matters), and I need some help (links, advice, etc.) with changing the bushings on the rear suspension.
Any and all help would be appreciated. Thank you.
I did a DIY awhile ago.
If you want the pics, send me an email.
https://www.civicforums.com/forums/4...ht=DIY+bushing
2 bushings are easy, 1 is a pain in the ***.
that's exactly what i was afraid of, the one from jc whitney was a buck twenty, they say it's performance, i've just never bought from jc whitney, but thanks for the DIY install, that'll save me some time. Also when you take the upper trailing bushing out could you possibly use a air hammer, or a sawzaw with a hack saw blade to cut thru the outer metal piece of the bushing. Anyways thank, and take it easy
You can get a whole ES set front and rear for $120. http://www.upgrademotoring.com/suspe...-Acura_App.htm
Check out summit racing
http://www.summitracing.com/
But that metal ring on the outside of the bushing needs to come out. Me and my buddy had the same problem with motor mounts for a 96 eclipse gst, they don't make inserts, so you have to take out all the rubber in the center and either cut thru the metal outer band with a sawzaw or as we did it hammer and screw driver, and about a hour of constant pounding to make a cut thru the metal bands and then pops goes the weasle, after a little convincing. But everthing about that rear bushing looks almost identical to thous motor mounts on the GST, rubber glues to the metal outer band and glues to the inner metal rod. I'm hoping i don't have two days down time, anyways thanks for the insight talk with ya later
Ziggy1999
Oct 15, 2015 07:56 PM
meicalnissyen
Sep 25, 2015 12:12 AM
