Battery Light
Old May 4, 2015
WLakers's Avatar
WLakers is an unknown quantity at this point
Battery Light
So yesterday my battery light came on, and my subwoofer(and its respective amp) went out. It would periodically come back and the light would go away. Well today it never went away and no subwoofer, and at one point the other speakers went out too. I came home and checked the voltage, and it was reading 16.3 while on and 12.4 off. 16+ seems a bit high to me...
Anyway, no other electrical issues yet...
New stuff:
Ok so now my radio has turned off a few times too, not sure if my stuff is protecting itself or what, but all are on when in idle in drive. When I start driving some go off some don't. Battery light is off as well until I start driving.
Old May 4, 2015
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: Battery Light
I would suspect once you start driving the alternator spins faster and is outputting more voltage than it should. I would get your alternator checked immediately or at least check the belt that's on it and make sure it's properly tightened. If your alternator is outputting that high you could blow out the ECM.
Old May 4, 2015
GolNat's Avatar
Prelude Owner
Re: Battery Light
Sounds like it might be a voltage regulator issue.
Old May 4, 2015
WLakers's Avatar
Re: Battery Light
Voltage regulator would mean new alternator too or no?
beantech
Jun 15, 2015 07:09 PM
HiImBrandon
Jun 1, 2015 07:34 AM
MiniMi
May 27, 2015 01:57 PM
trellex
May 24, 2015 04:39 PM
tylerginevan
Apr 27, 2015 12:29 PM
