defrost
Old Oct 31, 2013
psi 2148's Avatar
psi 2148 is an unknown quantity at this point
defrost
i have a 1999 civic lx. when I turn the **** to defrost the ac light does not come on and air does not come out of the defrost vents. I don't know what is going on and wondering if there is a fix that I can do myself. what is the prob.
Old Oct 31, 2013
Stock 99's Avatar
Re: defrost
Even when it is set to defrost the AC won't come on until the fan switch is turned. Do the fans work at all? Try the fan switch at all settings and tell us the results.
Old Oct 31, 2013
psi 2148's Avatar
Re: defrost
when switching it to the defrost mode the ac should automatic turn on and it does not. and the air does not blow through the defrost vents at all. even if manually turning on the a/c
Old Oct 31, 2013
Stock 99's Avatar
Re: defrost
In my 99 Civic the AC does not come on in defrost mode unless the fan switch is turned on (and the fan is working). If your fan only works at it highest setting then it's probably the power transistor. If your fan doesn't work period then fuse,blower motor, input power to the blower. If your fan works intermittently then fan switch.
...but your problem is fan related not defrost/AC related.
Old Oct 31, 2013
psi 2148's Avatar
Re: defrost
and yes the fan works in all setting except on defrost. the front wind shield does not get any air
Old Oct 31, 2013
schollianmj's Avatar
schollianmj will become famous soon enoughschollianmj will become famous soon enough
Re: defrost
ok, so when you have the selector set to blow on your feet it blows just fine.... Same with the front facing vents. But you turn the defroster on and.... does the fan stil blow and the air just isnt coming out on the windshield? or does your fan turn off when you select defrost....
I believe the selector is vacuum operated... might start checking vac lines under dash if the fan stil blows on defrost but the air just isnt diverted to the windshield. However if the fan turns off when you select defrost you have other issues.
Give us more info so we can help you better/easier.
Old Oct 31, 2013
Re: defrost
This uses electric servos. No vacuum.
Old Jan 6, 2014
psi 2148's Avatar
Re: defrost
sorry took a while to read. you are right the air come to the feet when selected and then to the upper or face and then when turning it to the windshield there is no air coming out. and it is electrical not vacuum
Old Jan 6, 2014
Re: defrost
Is the fan still operating at that time?
Where is the air coming out? (floor outlets or dash vents)
Got a friend with an identical car that works right? Swap the HVAC controller and see what happens.
Old Jan 26, 2014
psi 2148's Avatar
Re: defrost
the air does blow not the dash vents by the windshield but the ones by the doors. and it will at the feet
Old Jan 26, 2014
Re: defrost
At this rate, your cold season (if you have one of those) will be over before you get this problem figured out.
I'm sticking with this guess: Locate a known good HVAC controller to swap as a test.
Old Sep 17, 2018
DaBrother's Avatar
DaBrother is an unknown quantity at this point
Re: defrost
Have the same problem with a 1999 Civic DX. The, now wife, says the windshield defroster stopped working when the windshield was replaced. Do not see any correlation there.
Air does blow out the vents at each end of the dashboard to defrost driver and passenger side windows. The side windows do clear up after short time when frosted.
Guessing I also need to check into a HVAC controller.
garden772
Sep 15, 2020 01:04 PM
surelock22
Air Conditioning
Mar 5, 2013 11:52 AM
onebigwood
Sep 10, 2011 02:04 AM
fatsodoctor
Aug 21, 2010 09:17 PM
rucshaca
Apr 2, 2010 01:33 PM
