Civic will not start!!
Old Jul 30, 2013
KrisHino77's Avatar
KrisHino77 is an unknown quantity at this point
So a couple of weeks ago I installed the drivers side power door on my hatch and it worked well I installed the power wires into the fuse box... A couple of days ago I installed the passenger side power door. When I finished I tested it from the passenger side and it seemed to be working then I tested it from the drivers side and the passenger window went up and down. So then I switched the window lock from on to off and the doors stopped working. I tried to turn the car on and it wouldn't start not even a click or a sound just won't start.
I checked the starter but the starter is fine. I checked the clutch safety switch and that wasn't it I pulled the fuse box and checked for burn marks but nothing. Then I tested the box for power with a tester and it gets power the headlights work the radio works signal lights work the only thing is my doors and the car won't start.
Please help!!! If you need more info please ask thank you!!
Old Aug 10, 2013
Poopies's Avatar
Super Moderator
Re: Civic will not start!!
The what?
Did you try unhooking the wiring you installed and seeing if it will start?
Jonnie.
Jan 13, 2019 11:21 AM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
gabrown2
Apr 11, 2015 08:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
