98 civic ex cable reel help
Old Nov 2, 2012
JDM for Lyfe's Avatar
JDM for Lyfe is an unknown quantity at this point
i put in the cable reel for my civic and now the srs light is still on and the cruise control still doesnt work but the horn now works. the reel was from a 96 and i have a 98 if that would make a difference and im pretty sure i did it right. what else could be wrong?
Old Nov 2, 2012
Re: 98 civic ex cable reel help
I see 4 different choices for each year. Maybe you need to look in a parts catalog to see exactly which version of the car you can get a used one from. Match up part numbers and all that.
Old Nov 3, 2012
the cable reel works and should be right for my car sense it was from a 96 ex but my issue is the srs light did not come off. all data said the light should come on for 6 seconds and then shut off. it hasnt shut off yet. do i have to get it reset at the dealer? im pretty sure the airbag is good in it. cruise doesnt work either but thats probably for something else
Old Nov 3, 2012
You may have to clear the SRS codes.
Search, there is a DIY for it somewhere around here and all over the net.
Oh hell, here: https://www.civicforums.com/forums/1...srs-light.html
It uses what's called the MES connector in the dash fusebox, and a jumper wire and cycling the key....sort of a complicated dance.
CarStuff
Dec 6, 2020 12:52 PM
Nalmonte
Jun 3, 2015 11:01 AM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
civic_gt
Apr 19, 2015 08:15 AM
NukeSilo
Nov 4, 2001 09:37 PM
