(LEDs)Experts please help us
Old Jun 16, 2012
concepttheman's Avatar
concepttheman is an unknown quantity at this point
Ok I see that its been years since the led mod has been out. Many of you are still soldering LEDs to (I'm assuming) make your panels, etc., brighter.
Ok now 2012 we now have the leds with the resistor already implanted, which you can buy online. People if your new to leds fire away your questions to the experts like gearbox, diskreet, and so fourth.
My first question is I bought a 194 from ledoptions.com and it fits, and is a t10.
When I screww it in it doesn't light up. (Tried both ways)
When I put the stock bulb back in it works.
Here is the link with pics
http://store.ledoption.com/194-168-1...-Bulbs-s/2.htm
I ordered the first one. Does anybody know why this doesn't work but stock does?
Somebody please reply.
Thanks.
Old Jun 16, 2012
Re: (LEDs)Experts please help us
Connect your LED directly to a car battery. Does the thing even work at all?
HTH
Old Jun 16, 2012
I will try that tommorrow cause I'm at work. I'm assuming it will work because its fresh out of the box. Did you look at the bulb in the link? Maybe its a voltage/watt problem.
Old Jun 16, 2012
NEW stands for Never Ever Worked.
The drawing looks like a standard #194 base.
NOPE, not if it will STILL light the normal 194 bulb.
Plugging a diode in the wrong direction would probably blow the fuse. You sure the original bulb still works in that socket?
Polarity, maybe...but you said you tried it both directions. Try that a few more times, just to make sure. LOL. The bulb looks the same from both sides.
Should rule that out and you said the original bulb still works. Right?
I'm no expert in simple LEDs, but I'm sure there IS going to be a simple answer.
Old Jun 16, 2012
Yes well just to confirm and prove the stock bulb works, I'm gonna do a video tonite and put the link on here for everybodys educational purpose...lol...(even though I'm the only one learning)...stay tuned folks....I feel so dumb. I'm going to school for nanotechnology and didn't start taking my core circuits and vacuum science classes yet...lol stay tuned for link.
Old Jun 16, 2012
Here is a link to what my cluster. Looks like. The middle bottom one is the one not working with the 360 led, along with the one on the upper right side (facing cluster).
http://www.clubcivic.com/board/showthread.php?t=59115
Old Jun 17, 2012
http://db.tt/RxgMcDmb
http://db.tt/9x1AQZFs
Okmi got it to work...
Pins were not out enough. These pics are for thelast one I have left (upper right) on panel. When I switch this screw in illumination with another it still doesn't work. Even with the original in it won't work. I know its a illumination because its labeled that. Can anyone help?
Day time pics are in the link b4 this post.
Thanks plz reply.
frank_kleng
Sep 29, 2015 10:55 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Michael Durkin
Transmission
Sep 24, 2015 12:35 PM
MamaBear2015
Sep 24, 2015 11:34 AM
J-Fly
Sep 10, 2015 08:39 PM
