no signals
Old May 29, 2012
dyltherock's Avatar
dyltherock is an unknown quantity at this point
no signals
my 2001 honda civic warning lamps and signals wont work but fuse is still good
Old May 29, 2012
Re: no signals
Engine compartment fusebox fuse #5
Dash fusebox fuse #19
Turn/hazard flasher relay? Looks like it should be the largest relay looking thing on the front panel of the dash fusebox.
I would have a wiring diagram and a test light out, and track down the real cause. No guessing.
HTH
Old May 30, 2012
rjones7755's Avatar
Re: no signals
Did you recently take off the dash? If you did you might have left the hazard harness unplugged...this would cause your hazards and turn signals to go out
Crazygrlinak
Oct 8, 2015 05:06 PM
sesi
Oct 1, 2015 02:03 PM
meicalnissyen
Sep 25, 2015 12:12 AM
