Need help connecting sub!
Old Dec 1, 2011
victaaaa's Avatar
victaaaa is an unknown quantity at this point
Hey guys, I'm a total noob when it comes to car audio.
So here's the situation:
I have a sub and 2 amps. The amps are wired (my brother did it a while ago).
I just need to know how to connect the sub to the amp, because I have no idea.
I've got some pictures here
Which amp do I connect the sub to? And how do I go about doing that?
Thanks!
Old Dec 2, 2011
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: Need help connecting sub!
You connect speaker wire to the speakers, run it to your amp, if you look at the 4 screws to the side of were your power wires are, the ones not being used and attach the wires there..then you should be good to go. Attach it to which ever sub you want to run your speaker..i would hook it up to the 600w amp if your speaker is rated to handle it.
Why do you have both amps hooked up and only one sub? what are you going to do with the other one?
ricer_em2
May 11, 2016 08:09 PM
haloway13
Nov 6, 2015 10:43 AM
Bruce2
Sep 27, 2015 08:45 PM
IronFist
Sep 25, 2015 07:13 PM
Bruce2
Sep 21, 2015 08:01 PM
