After Market Install on 2000 Civic
Old Dec 28, 2010
FblCivic00's Avatar
FblCivic00 is an unknown quantity at this point
I am installing a Sony radio in my 2000 civic. I purchased a wiring harness and connected it to matching wires. I have an orange wire and an orange//white wire left from the wiring harness with no match from the radio.
If these orange and orange/white are not connected the radio will not work. If I connect the orange wire to yellow wires, the radio only works when the engine is running and headlights are on.
Need help fast!
Old Jan 10, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
Re: After Market Install on 2000 Civic
use the wire from ur cig lighter wire
as it uses the same fuse
it only tuns on when u turn on the key
Old Jan 10, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
your radio should've came with a wiring diagram in the owners manual...make sure you wired everything correctly. not sure what sony uses for orange
Old Jan 29, 2011
sikciv00's Avatar
sikciv00 is an unknown quantity at this point
i deal with sonys in every car i have and ive never heard of that problem ive never hooked the orange wire up red to red yellow to yellow and ground to ground and plug the harness in and everything works i have a 00 with a xplode deck and it works perfectly fine
Old Jan 30, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
The orange wires are for illimunation and are not needed cap them off and tape them to the rest of the wires. Do not connect them to the cig lighter plugs as suggested by asianboy he does not know what he is talking about. The illumination wires are usually hooked to the factory dimmer wire and sony does not have a wire for this. It will work just fine without it.
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
