O2 Sensor
Old Nov 17, 2010
jeffrey1089's Avatar
jeffrey1089 is an unknown quantity at this point
Exclamation O2 Sensor
So I bought a 99 Civic EX, the guy I bought it from was a D-Bag and didnt tell me he put the car together half ***. Now I have to Re-Wire my front O2 sensor, the one ahead of the cat. I need the color code or a wiring diagram for the O2 sensor running into the enging harness. I keep throwing the O2 sensor code, even after replacing both sensor. Does anyone have it or know how to Re-wire it? I have the 2 black wires correct, not sure about the white wire and the green wire. Also does the white wire have to be insulated? Please help.
Old Aug 14, 2011
Whatr_udoing's Avatar
Whatr_udoing is an unknown quantity at this point
Re: O2 Sensor
I had the same problem replacing with universal sensors. Here's the chart they provided: http://stores.ebay.com/GLOBAL-AUTOMO...G-DIAGRAM.html Don't assume the two black wires are the heater. Ohm them out. Should be ~ 10-40 ohms. It's much better to buy replacements with the connector and no splicing. If they're OEM then make sure you have +12v on one of the heater wires at the wiring connector to ground. Otherwise, follow the troubleshooting guide in the service manual http://files.clubcivicquebec.com/Man...ice_Manual.pdf (takes a while to load, 2000+ pages, section 11).
Old Aug 25, 2011
robtec88's Avatar
robtec88 is an unknown quantity at this point
Re: O2 Sensor
Why are you so sure it's a wiring issue to the O2 sensor? Have you had anyone hookup to the computer and watch what is actually happening with the engine sensors? What O2 code are you getting?
Unless you have a code that points to the O2 sensor's heater circuit being an issue, never assume any other O2 sensor code pertains to a bad O2. A lot of O2 sensor codes are set because of a problem causing the O2 to go out of it's expected parameters such as: vacuum leak(s), too rich fuel mixture, too lean fuel mixture, etc...
And yes, you should always insulate any wiring you do when it pertains to sensors and anything the ECM is monitoring and controlling.
BootyDo
Jun 21, 2016 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
Dani1993
Jul 24, 2015 09:02 AM
mistermenphis22
Jul 13, 2015 04:43 PM
