97 civic dx headlight wiring problems
Old Feb 12, 2009
troywhitney13's Avatar
troywhitney13 is an unknown quantity at this point
I have a 97 Civic DX, the passenger low beam does not work, I bought a new set of lights today and it still doesn't work. The drivers side high and low beam works fine, only the high beam on the passenger side works. I have also swapped the bulbs from the drivers side to the passengers side and still the same problem. Also when I have my low beams on my parking lights go off, when i flick to high beams they come on. I have absolutely no clue what is going on here, if someone could help and shed some light on this situation I would greatly appreciate it.
Old Apr 2, 2009
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
Re: 97 civic dx headlight wiring problems
I would check your fuses. There should be a 10A fuse fore each low beam and each high beam. As for the parking lights problem, I have no clue unless you possibly tapped something into that circuit i.e. fog lights, halos, running lights, driving lights, ect. Double check any aftermarket wiring kits that intergrate into the lighting system.
Old Apr 2, 2009
sounds like something messed with the wiring, or possibly the headlight switch. or a bad ground connection.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
usajags84
15
Aug 19, 2015 03:12 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
NukeSilo
Nov 4, 2001 09:37 PM
