93 Si gauge cluster problem
Old May 6, 2008
tomatoSi916's Avatar
tomatoSi916 is an unknown quantity at this point
So i bought my 93 si hatch with a jdm cluster in kilometers per hour. I traded it straight up for a usdm cluster so i can have mph readings. When i put the new cluster in the rpm gauge does not read correctly. It will redline at about 6k rpm, which is 1200rpm too low. So i went to the junk yard and pulled a cluster out of a civic ex and the rpm gauge would climb too fast and still not redline. Any ideas of why this is happening? i adjusted the needle and my idle says 1200 rpm and still will only go up to 6500rpm and hit rev cut. I need to fix this asap. thanks in advance.
Old May 14, 2008
Re: 93 Si gauge cluster problem
nobody can help eh?
Old Jun 26, 2008
is there a difference in the wiring or anything? any help at all. also the blinker will not blink anymore just stays lit, is there a relay that needs to be replaced? i really need the help.
HiImBrandon
Jun 1, 2015 07:34 AM
Ma213802
May 18, 2015 07:01 AM
bahena08
Apr 11, 2015 05:09 PM
0100010
Jan 6, 2002 12:54 AM
guy
Dec 25, 2001 09:51 PM
