drum brakes
Old Feb 19, 2011
yoba's Avatar
yoba is an unknown quantity at this point
drum brakes
Anyone know a good how to on this ? I'm wanting to change my rear drums but need a little help!! And off topic, but what would cause my valve cover bolts to leak oil ?????
Old Feb 19, 2011
MelJ's Avatar
Trance Addict
Re: drum brakes
If you look closely, there are little gaskets or seals underneath the bolts. When they get old, they get brittle and start to crack, which is probably a good indication they need to be changed. You can get a valve cover gasket, spark plug tube seals, and those cover bolt seals as a set at local auto parts stores as a set. What do you need to know about drum brakes? I've only dealt with them on my Corolla and they were a PitA, but they rarely wear down since a good majority of the braking is done in the front. I think there is an adjustment screw to toy around with them. I don't have my manual around ATM, but there are a few guys here who can help you with that.
Old Feb 19, 2011
Kennykid2002's Avatar
Kenny the Ricer
Re: drum brakes
Are you looking to change the pads in your drum brakes, or are you looking into a disk conversion??
A little more specificity would be best
And oil leaking could be a sign of a gasket gone bad
Old Feb 19, 2011
BobDobolina's Avatar
TRUST me! I'm Idiot Proof!
BobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura about
Re: drum brakes
The SEARCH function is your friend, friend. Clicky HERE
Or try google, or MANY, MANY others...
Old Feb 19, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: drum brakes
download the pdf manual I posted on the 6th gen main page it has a complete breakdown on the procedure.
Old Feb 20, 2011
MelJ's Avatar
Trance Addict
Re: drum brakes
hey newfied, you should put that pdf in your sig to help the newbies out .
Old Feb 20, 2011
Newfiedan's Avatar
Re: drum brakes
or beat them on the head with the pdf lol, yeah I agree might be a good idea to add to the sig seeing as how many of them do not know what the search function does lol.
Old Feb 20, 2011
MelJ's Avatar
Trance Addict
Re: drum brakes
Mad Dog Tannen
Sep 12, 2015 12:48 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
