Crankshaft Positioning Sensor
Old Oct 26, 2018
Skaterforeva1's Avatar
Skaterforeva1 is an unknown quantity at this point
Hey guys im new here and i bought a 98 civic EX that I had been told kept overheat assuming it needed a headgasket. The only thing that was wrong with it was the heater core hose had busted under the distributor. I fixed that but it sat for about a week after i drove it and sprayed coolant all into the distributor. Now its extremely hard to start and codes p1336 and p1337 (P1336 CKP Sensor B Range/Performance P1337 CKP Sensor B Low Input). I have to press the gas to start it and when it runs its missfiring bad and has no power. It also doesnt sound like vtec is kicking in. I was looking up and I keep hearing that the sensor is in the distributor or behind the pully. I also heard that this shouldnt cause performance issues. Before I start daily driving I would like to figure out if i need to just replace the dizzy or the sensor.
Old Oct 27, 2018
Re: Crankshaft Positioning Sensor
What does your service manual say about the codes?
Hint: The sensor at the crank pulley is CKF not CKP.
The distributor got WET you need to start there (high voltage and liquid do not work together)
If it popped the hose and ran hot, it probably will need a head gasket
Old Oct 28, 2018
Im not sure if it is in timing. My friend said that's what it sounded like so I have decided to go ahead and do a timing belt/head gasket. So I'm gonna go ahead and replace the sensor. I did replace the distributor cap, plugs, and plugs. Then i unpluged the sensor by the crank and it still ran like the timing was off.
Old Oct 28, 2018
P1336 and P1337 are for the ckf sensor next to the crank pulley, but that sensor is not used to run the engine. I'm pretty sure you can unplug it and the engine runs exactly the same without it. (sometimes after a timing belt job the wires for the ckf sensor didn't get tucked into their little holders, then a short while later the alternator belt cut the wires apart causing fault codes)
Did you remove the distributor to do any of your other work? Did you line it up exactly the same as it was before removal? Did you check ignition timing when you reinstalled the distributor?
Has the timing belt been inspected, are the cam/crank actually in time?
Do either you or your friend actually know what the car is supposed to run like when it's in good shape?
I'd want to make sure this was actually gonna solve a problem before wasting a ton of time and money.
kevin2001
May 22, 2021 03:49 PM
honda.lioness
Sep 17, 2017 04:19 PM
IROKGEN7
38
Feb 18, 2016 07:27 PM
AA_Sharky
Oct 18, 2014 02:02 PM
xRiCeBoYx
Engine start problems
71
Apr 9, 2011 01:40 PM
