97 honda civic, starting issues, runs fine once started
Old Oct 21, 2018
jsan101's Avatar
jsan101 is an unknown quantity at this point
Unhappy 97 honda civic, starting issues, runs fine once started
hey all,
ive posted this to different forums and i cant seem to find what the cause of the problem is. i have a 97 honda civic ex, 187k miles. since about july, the car has been starting abnormally. i took it to my local mechanic who i trust, and got the starter replaced. it was good for about a day or two, but the issue began again. the starter will either make a grinding noise with the flywheel, or it sounds like the engine just isnt cranking normally. i dont really know how to explain it, whether the engine is just starting without the starter properly engaging, or its just stuttering when starting.
once the car is on, its golden. but it'll happen again if i turn it off and turn it back on. it wasnt as frequent before, but with the weather getting colder, i fear itll get worse. here are 3 videos of the issue.
Old Oct 21, 2018
Wankenstein's Avatar
Re: 97 honda civic, starting issues, runs fine once started
Has the battery been tested or replaced recently?
Check all grounds for loose connections
Sounds like the starter is dragging a bit and may be related to the above mentioned.
Flywheel may be damaged? Could get it on a lift and inspect the flywheel teeth while the car is in neutral.
Old Oct 21, 2018
GolNat's Avatar
Prelude Owner
A damaged flywheel could definitely be the cause. I would check battery and all connections first. Even the ones at the starter could be loose.
Old Oct 22, 2018
jsan101's Avatar
the battery was tested and it was fine. I had the alternator replaced in July. when they replaced the starter, they inspected the flywheel and said it was fine. maybe it should get looked at again.
Old Oct 22, 2018
jsan101's Avatar
I will check the connections near the battery and starter.
Old Oct 22, 2018
Check all grounds connections to chassis and engine as well. If rusted then remove and clean the terminal and/or chassis with a brass wire brush.
subless
Aug 13, 2018 11:38 PM
g4384063
25
Dec 14, 2017 10:54 AM
goofy gorilla
Sep 20, 2017 09:18 AM
bdwn0069
Dec 1, 2013 10:18 PM
BRCivic
18
May 28, 2005 09:20 PM
