Oil light on after removing bad speed sensor
Old Aug 30, 2018
newGuyneedHelp's Avatar
newGuyneedHelp is an unknown quantity at this point
Old Aug 30, 2018
Wankenstein's Avatar
Re: Oil light on after removing bad speed sensor
It's most likely not the electronic spray in oil but more likely corroded wires causing ECU feedback/idle issues. Your car may be in limp mode? You may have to splice in another speed sensor harness. First, try an ECU reset (idle relearn) and report back.
ECU reset:
1) Turn off all electronics (radio, dome light, headlights, interior lights, etc..)
2) Disconnect the negative terminal from battery
3) Turn on headlights and press brake pedal a few times to discharge any residual current
4) Wait 5 minutes and then reconnect negative cable terminal to battery (make sure headlights and all electronics are turned off prior to connecting battery).
5) Start the engine and let it idle until radiator fan engages twice (roughly 15 minutes)
Old Aug 30, 2018
Old Aug 30, 2018
Originally Posted by newGuyneedHelp
Started the car up and both the oil light and cel were gone! idled really rough for about 2 min then stalled out. After stall the oil light came back Started her up again and she revved up to about 1000k rpms sat there for a minute then stalled again. Could it still be the bad speed sensor causing it to stall?
Is engine oil at the proper level?
Did you try an ECU reset?
Did you purchase a Honda Genuine 9oem) speed sensor or aftermarket? Aftermarket suck. Also, the speed sensor is transmission dependent (manual or automatic) and you'll want to match up the speed sensor's gear teeth to the one you removed to ensure they match correctly. Have you checked continuity and voltage of speed sensor harness?
Old Aug 30, 2018
Old Aug 30, 2018
Also how do you line up the teeth correctly? All i can see is oil where you insert the sensor
When I replaced one a couple years ago I pulled it from a junkyard. If you pull one from a junkyard bring your current one in to match up with the pulled one. Make sure the speed sensor's gear (bottom) is the same thickness, teeth are in good shape and in the same direction as the current one. This link may help: https://honda-tech.com/forums/honda-...nsors-3019131/
Here's a VSS testing video:
Old Aug 31, 2018
Old Aug 31, 2018
the connector looked just as bad if not worse
The center pin was corroded so bad it's nonexistent?
Old Aug 31, 2018
Old Aug 31, 2018
Old Aug 31, 2018
Old Aug 31, 2018
replace the vss connector though, it's as ugly as the corroded sensor.
Imo oil light should be unrelated.
Old Sep 1, 2018
Deleting all of your posts doesn't help anyone. Shall we restore the posts for you?
iSamoStefan
General
Jan 8, 2019 03:10 PM
alex_nyc
Jun 18, 2015 10:11 PM
td1238
Mar 2, 2012 06:39 PM
Slammed99Si
Feb 17, 2006 03:14 PM
HELP_ME
Jun 6, 2004 06:03 PM
