Intermittent Shaking
Old May 12, 2018
JakeBe1234's Avatar
JakeBe1234 is an unknown quantity at this point
I have a 99 Honda Civic EX automatic (157k miles) and have been experiencing a shaking in the front end of the car that comes and goes. It seems to be related to temperature as it happens midday, but rarely happens at night.
Symptoms:
  • Happens during normal driving
  • Brake pedal becomes very stiff
  • Feels like a thudding
  • Wheel shakes and speed is affected/have to put the pedal down to keep speed.
  • Goes away eventually
Known Good:
  • Replaced both front wheel bearings less than a year ago
  • Both axles replaced
  • Calipers and hoses were replaced by a local shop about a year ago
  • Replaced Pads and Rotors about 3k miles ago (no thudding while braking unless the problem is happening)
Any suggestions are extremely appreciated as at this point I am kinda at a loss of what it might be.
Old May 12, 2018
Re: Intermittent Shaking
When it gets to this point, stop and check if you have a wheel and brake that's incredibly hot
Which wheels/brakes are affected?
If more than one wheel is screaming hot, I'd suspect a Master cylinder related issue such as misadjustment, failure, oil in the brake fluid, or something is keeping the brake applied when it shouldn't.....(misadjusted light switch?)
Old May 12, 2018
JakeBe1234's Avatar
I will definitely see if one wheel is hotter than the other next time this happens. The master cylinder is original as far as I can tell, I have had the car for the last 30k miles. The brake fluid itself looks clean when I checked the reservoir just the other day. When you say "misadjusted light switch" what are you referencing ?
jamesbbh
Jan 24, 2003 04:52 PM
MistaFreeze
Jul 26, 2002 03:28 PM
bake
Jun 11, 2002 11:54 AM
2Hottie
17
May 31, 2002 01:29 AM
RickyRocket
Nov 30, 2001 10:14 AM
