Blinking/Flashing battery light [SOLVED]
Old May 9, 2018
FearWRX's Avatar
FearWRX is an unknown quantity at this point
Hi guys.
I know that there's a lot of topics about this (seems like a commom issue for Hondas) but, i swear, i've read MOST of them and never got a solution.
I own a 99 Civic sedan LX, automatic, 106.300km (~62k miles) and my battery light very often comes back back to haunt me.
What i made, recently, by recently I mean, this week (i've rode 100km with the car after the service, which, before the service the battery light was already blinking), I've replaced ALL the belts, and the brushes of my alternator got repaired (changed), in fact, it looked like the problem was solved, but today, driving around the city, she's back on my dashboard.
He's charging correctly and the only thing I could appoint is that my battery has already 3 years, but the car starts fine every morning, no problems with that too.
Also, I see no corrosion in any grounds, neither the battery, nothing seems out of place.
So, here is my last resource. What could be my problem now?
Thanks in advance.
Old May 10, 2018
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
re: Blinking/Flashing battery light [SOLVED]
Put a volt meter on the battery and see if the voltage is normal when the light is flickering. That way we know if there is an actual problem, or if the car just thinks there’s a problem.
Old May 10, 2018
Get the car so the battery warning light is staying on
Unplug the 4 wire connector from the alternator
If the warning light then is off, the alternator is bad.
Old May 11, 2018
FearWRX's Avatar
But that's exactly the problem. If blinks at random places, at random hours and random conditions for no more than 2 seconds. It's impossible for me to stop the car and try to diagnose it while driving.
And stopped the light never blinkered.
Old May 11, 2018
Get something like this then:
Amazon Amazon
Old May 12, 2018
FearWRX's Avatar
Originally Posted by D17VTECPOWER
I didn't know that something like that existed, i'll get one of those. Thanks for the suggestion.
Old Aug 5, 2018
FearWRX's Avatar
Here's the update after some time and turned it out that the problem were the voltage regulator (the part which is at the back of the alternator).
Replaced it and no more battery light on my dash, plus, my dashboard lights and headlights now are static, before if you looked at it closely you'd see that they were kind of "oscilatting".
Edit: I, at a cold morning, got a multimeter and measured it right after i started the car. That time the light were blinking and my alternator were charging from 14,7V ~ 16.3V, that's what got me directly to the voltage regulator.
If some admin see this, please add the tag [Solved] to it, please.
Old Feb 16, 2021
Randy Stoner's Avatar
Randy Stoner is an unknown quantity at this point
Re: Blinking/Flashing battery light [SOLVED]
ELD
electrical load detector.. causes alt light to blink.
in 95 Lude was built into fuse box
​​​2003 crv its bolted into the fuse box.
2x I've ran into this
trav719
Nov 10, 2014 12:17 PM
hoypinoyskee
Nov 16, 2012 02:43 PM
popee
Nov 2, 2007 11:49 PM
ManUtd0018
Nov 2, 2006 11:41 AM
DaveXP
Sep 22, 2004 12:49 AM
