Restore a 96 Civic EX Coupe Back to Life
Rep Power: 0 Restore a 96 Civic EX Coupe Back to Life
Hi everyone,
This is a long post so please bare with me here!
I've just recently acquired a 6th Gen Civic. I'm more familiar with 7th Gen Civics but they seem very similar.
It's a 1996 Honda Civic EX Coupe (Automatic) w/ 184K miles. I have no idea how long it sat for but it was neglected for sure.
Previous owner suggested engine was swapped around 130K but I can't really verify that.
I tried looking on the engine block where the engine number is but it's really dirty so I'll clean it tomorrow with a brush and see which D16 engine it has.
Upon receiving the car, I noticed a check engine light went on as I was driving on the freeway (car runs and drives poorly at the moment).
Also, the e-brake dash light was turning on when accelerating from a stop.
I did some research and it suggested that my brake fluid was low so I topped it off temporarily (I will be doing a complete change/bleed soon).
It also has trouble hitting 3rd gear (trans slips?) and shifting through the gear shifter (going from Park to Reverse to D3). It shakes the car heavy.
Could someone verify if this is because the transmission fluid is low? I checked the dip stick and it was pretty low. Hopefully it'll be fixed by a ATF change.
Also, I went to change the oil and the old oil was very gunky and sludgy, not to mention really black and dirty.
Should I put a motor flush in it (debatable topic I know but just wanna make sure it's clean in there since it was sitting for who knows how long).
Here's what I'm going to do to service the car (Honda fluids are 10% off right now at my local dealer)
1. Oil + Filter Change (Mobil-1 High Mileage 5W-30 Oil + M1-104A Filter)
2. Honda Genuine ATF-DW1 Automatic Transmission Fluid CHANGE (not flush)
3. Power Steering Fluid Change/Flush (w/ Honda Genuine Power Steering Fluid)
4. Coolant Change/Flush with some fresh new coolant (there was barely any in the reservoir)
5. Brake Fluid Flush (bleed out old fluid and top off the master cylinder on all 4 sides)
6. Replace brake rotors/pads (they're rusted). Calipers are rusted too but I may be able to restore those)
7. Replace spark plugs with new NGK V-Power 2262 (ZFR5F11) spark plugs (don't really wanna put Iridiums/Platinums)
8. Clean out throttle body to get rid of any carbon build up
9. Clean out air intake filter (there's no air box, it's been replaced with a cold air intake I believe that's what it's called)
OK, now here is my question.
- What else should I do to bring this car back to life?
- What other mods would you suggest?
Please let me know if I should or shouldn't do any of these things!
Please keep in mind the car has been sitting for who knows how long and needs a major service!
Thanks for reading this long post!
Received 1,149 Likes
Rep Power: 485 Re: Restore a 96 Civic EX Coupe Back to Life
not that it'll tell you much, but I know on a D17 I swapped into my 7thgen, there was a VIN plate on the backside (oil filter side, kinda high up) on the block. At least will tell you what year trim it came from.
If you're gonna do an oil change anyways, you can always pull the oil pan to see how gunky it is. May give you insight to how clean the internals of the engine are.
Tranny fluid, may wanna do a few drain and fills to try and get some crap out of there.
Any records of timing belt, water pump, etc. done? A few hundred bucks for some peace of mind?
like you, I"m not very familiar with the D16 and am more well versed on the D17
Rep Power: 0 Re: Restore a 96 Civic EX Coupe Back to Life
I'll take a look today in more detail on the engine block.
Probably a D16Y8 Thanks for the tip on the tranny fluid.
Unfortunately, I have zero records of anything serviced (which is why I wanted to completely tuneup/service the car).
The only record I have is oil change in May 2017 and supposed D16 engine swapped sometime last year (which may not even be true).
My biggest issue right now is just the overall engine performance with the gear shifter and hitting 3rd gear.
If I can resolve that issue without the car shaking like crazy, I will invest in changing the timing belt/water pump.
Hopefully, the tranny fluid service will solve that issue (I really, really hope so).
Hi everyone,
RIPSAW
19
12-02-2014 06:35 AM
BahstonCivic
10-02-2012 01:18 PM
tungstenc
12-09-2006 05:49 PM
