Shift linkage flipped upside down somehow.. please help
Mechanical Problems/Vehicle Issues and Fix-it ForumIf you've got a problem you just can't figure out, a noise you can't diagnose, or a Check Engine Light that won't go away, ask about it here!
Hi everyone,
I replaced the shift lever on my '00 EK hatch then when I got back in the car after tightening everything back up I found the shifter won't hardly move in any direction.. I got back under the car and it seems MAYBE the shift linkage somehow got turned on it's side and I had bolted it back onto the shift lever upside down. I removed the 12mm bolt to see if I could rotate it back to to its original position and it won't budge. Clutch in or out. I have no idea what else to even try at this point. It's my daily and I need to get it functioning very soon so any ideas are very appreciated!!! Thanks It's called shift rod in this diagram
