Is it ok for springs to be upside down!??
Old Aug 5, 2002
eddie's Avatar
eddie is an unknown quantity at this point
Well..i took my front neuspeed springs and put them upside down. In the first place, the springs were set normal. But i thought if i flipped the springs(top to bottom) that will reduce the clickin. I found out that it does reduce some of the noise..but it's still makes a grindy and click noise when moving at low seepd(7mph). Does flippin the springs upside down effect the tire,shocks, or suspension?? Ohhh i'm thinking about buying some struts any advice?? Does anyone know where i can find some cheap price and decent quality?? Thanks everyone has been much help on this site!!
Old Aug 5, 2002
MSoft's Avatar
MSoft is an unknown quantity at this point
double post?
Old Aug 11, 2002
dragoon's Avatar
no, no upside down springs! very horrible ride quality
Old Aug 12, 2002
eddie's Avatar
Well..just my front and rear are upside down. On the rear it wouldn't fit but uspide down. If you think about it..it should fit and peform the same way.
Old Aug 12, 2002
dragoon's Avatar
from my experience on my friend's maxima, they sure did not perform the same way. make sure they're put in properly. as for struts, all we have are koni yellows - i'm waiting for a cheaper alternative.
Old Aug 12, 2002
Chris2k1civic's Avatar
Super Member
Chris2k1civic is an unknown quantity at this point
well.. if u have a clicking noise in ur front when u turn then u need to drop the strut and grease it up.. the spring is getting stuck and when the force moves it.. it just goes click try that.. and put ur spring right side up...
Old Aug 13, 2002
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
Answer to all of your questions....
I dont wanna be an [IMG]i/expressions/moon.gif[/IMG] but try a search next time... I hated it when people said it to me I know, but yeah, that was just before I even knew wut a friggin search was... It helps though, and it also saves you from asses worse than me that will eventually yell at you at times...haha.... good luck man...
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
